Removed all side panels. Installed rudder pedal bars. Made stainless steel bushings for rudder cable turnbuckles. Drilled out one end of each turnbuckle to accept bushing. Made jig to hold rudder pedals in neutral position. Swedged rudder cables to turnbuckle ends. Adjusted turnbuckles so that rudder pedals clear firewall with full pedal extension and full brake travel.
Started work on mounting firewall end of brake hoses.
