Drilled and clecoed tank top to cap strip layup overhang material for future alignment and clamping. Overhang will be removed when tank is complete. Removed tank (with release tape on the underside) from cap strip layup. Cut away material in the center of each compartment leaving only cap strips. Sanded underside of all cap strips, upper sides of tank and baffles.
Shaped and sanded hysol/flox around lower sight gauge tube in tank interrior and tank exterrior.
