Cut and fit center piece for inboard tank side. Cored edges of fwd inboard piece. Filled cored areas with micro. Taped fwd and ctr pieces together on outside. Microed all 3 pieces into place.
Started work on aluminum insert. This piece will hold the upper and lower float switches for the auto fuel transfer system as well as the Pillar Point sensor for Low Fuel Warning system. Drilled and tapped 3/8" thick piece of 2024 T4 aluminum for 1/2" NPT thread.
