Sanded micro on rudder. Install rudder. Check clearance. Remove rudder. Sand v stab trailing edge. Repeat 12 times. Sanded micro on v stab leading edge. Applied superfill to v stab to fuselage junction. Release taped left elevator access panel. Microed over panel edges. Cut kerf when semi cured.
