Made shelf for ELT out of 4 bid carbon. Shaped to fit into lower aft fuselage just aft of inspection door. Attached shelf with epoxy/flox. Need to add 4 bid over shelf and onto fuselage sides.
Attached 2 - 1/16" phenolic pieces to floor in front of lower panel. Bid will be added later.
Removed instrument panel and trimmed panel mounting brackets.
Added nutplates to aluminium plate over rudder bar support on top of nosegear well. Attached AN3-17A bolts from below in wheel well.
