Removed fine-line tape around cabin door window. I had not removed this immediately after painting due to the fact that I had a run and thought that I was going to repaint. Why remove the masking when you're going to repaint anyway? LESSON: Always remove masking asap after painting, even if you are going to have to re-mask. After three days, the paint had hardened to the point that it had to be cut with an exacto knife...not good.
Wet sanded cabin door with 1500 grit.
Disconnected and hung elevators on drying rack.
Tim O'bar came over and gave me lots of painting tips from the point of a professional painter. I've got lots of room to improve.
