Fabricated airfoil shaped vent guard from 1/2" phenolic. Attached phenolic to inspection plate with 2 wood screws and micro. Made micro fillet around guard.
Fabricated preliminary vent tube from 3/8" AL tubing. Drilled fuselage bottom just behind vent guard.
Turned wings over. Final sanding and inspection of wing bottoms. Wiped with acetone. Both wings, top and bottom, now ready for the paint booth.
Cleaned rudder, ailerons, flaps, elevators and nose gear doors in preperation for final bodywork and SmoothPrime.
