Trimmed outboard edge of right flap to provide clearance with aileron. Lots of installing, checking, removing, trimming and installing.
Removed foam core in extended portion of flap. Replaced with micro.
Bolted wings together. Trying to figure out the best way to support and turn them during painting. With wings bolted together it seems that the assembly is too heavy and akward. Supporting each wing seperately requires a method to support the wing tip. That'd be a lot of weight on the wingtip flange. Need to come up with a better plan.
