Mounted small toggle switch on hydraulic valve mounting bracket. The starter is wired through this switch as well as the normal start button on the panel. It will not be visible in the cockpit but it will be reachable, if you know where it is.
Mounted two mini locking toggle switches on lower panel for power switches for the P-Mags.
Rerouted feed wire powering the aux fuse panel on the lower panel. This aux power panel is now powered from the essential bus.
