Bills Web Site
LNC4
Bodywork
Drilled and countersunk holes in fuselage for cabin door striker plate lower attachment. Installed 3/16 machine screw and nylock nut.
Riveted baggage door arm per manual.
Removed washers from under fwd cabin door hinge. The alignment that they provided was insufficient to justify their placement.
Added first pass of micro around cabin door.
Applied micro to upper/lower fuselage joint on right side of aircraft.
cabin door striker attach
baggage door rivets
starting cabin door bodywork
S6-S Home
LNC2 Home
LNC4 Home
6961
Aircraft Kit
Assembly
Doors
364
526
374
Flight controls
Flight controls
Fuel
697
1545
Hardware
Hydraulics
Instrument Panel
25
241
Insturment Panel
Misc.
758
Panel
Paperwork
Weight & Balance
1136
