Sanded yesterday's layups attaching the nylon strikers.
Fabricated and installed 1/8" phenolic mount for microswitch. The microswitch will open when the lock lever is in the locked position, turning off the DOOR light on the panel. This light will also be wired to the cabin door.
Started bodywork on fuselage joint. Applied micro to left side of fuselage.
