Fabricated spacer washers for baggage door locks from stock 5/16" aluminium. The phenolic lock mount is too thick for the mounting plate to capture the locks. These spacer washers fit on the lock barrel and allow the mounting plate to firmly press the locks into the phenolic recepticle in the door.
Fabricated a water seperator for compressed air in the paint booth. The blue container will be filled with ice and water. Compressed air enters through the quick disconnect at the top of the coil and exits into a tee at the bottom of the coil. Water that has condenced in the tubing will flow down to a ball valve below the container that will be just barely cracked open. Dry air will exit the top of the PVC pipe through another quick disconnect.
