Installed nutplates on fuselage for cowling attach. There were 3 locations on the right side where there was not room to get the angle drill or rivet squeezer. In those 3 locations, I mounted the nutplate on 4 bid carbon and bonded the carbon to the fuselage.
Bonded carbon spacer ro right side of cowling nose wheel cutout. This spacer is 6 bid at the forward end and 4 bid at the aft end. The spacer will lower the cowling surface slightly at the right forward portion of the nose wheel cutout.
Temporarily installed engine exhaust system. Cut cowling to allow exhaust pipes and heater muffs to extend below lower cowling surface. I will make fairings to cover these parts.
