Bills Web Site
LNC4
Nose gear door body work
Sanded yesterdays micro around nose gear door. Lots of fun sanding upwards. Came out pretty good, need to add a little skim coat.
Extensive filing of alignment tabs and adjusting closing rods to assure that doors close symetrically and that the tabs don't hang up.
Mounted nose gear down micro switch on overcenter link.
Wrapped dash 3 hose with nylon spiral wrap for abrasion resistance. Mounted adel clamp on gear box and routed hose to absorb movement of gear trunion.
nose gear doors
nose gear micro switch
left brake line
S6-S Home
LNC2 Home
LNC4 Home
6961
Aircraft Kit
Assembly
Doors
364
526
374
Flight controls
Flight controls
Fuel
697
1545
Hardware
Hydraulics
Instrument Panel
25
241
Insturment Panel
Misc.
758
Panel
Paperwork
Weight & Balance
1136
