Layed up 3 bid carbon on outboard side of lower copilot footwell tank extending 1 inch onto released upper tank. Lower tank now has a "fence" around 3 sides allowing the upper tank to be slid in perfectly aligned and stop when forward ends are in the same plane (no pun intended).
Cut slit in fwd end of lower tank fence. Slit is aligned with toungue. When tank is pushed into place toungue engages in slit (uhhhh, no pun intended) and prevents any upward movement of upper tank.
Layed up 6 bid tongue on bottom of upper tank at outboard side at aft end of lower tank. A pocket will be layed up to engage the toungue and hold the aft outboard part of the upper tank from moving upward..
