Hans Marchners Web Site
Date:  4-9-2013
Number of Hours:  3.00
Manual Reference:  Ch 22
Brief Description:  Assembly of doors 1
The manual describing how to make a door of all the pieces can be improved. I would have appreciated more scetches and fewer pictures (which are not very accurate). Luckily the door assembly is not very complex - it's an inner frame and an outer frame covering two sheets of Lexan in between and with a lot of clever reinforcements in all corners. All the pieces fit very well together with a high degree of precision cuts. Also, the Lexan plastic is very flexible and does not seem to crack easily.
Outer frame
Outer frame
Inner frame
Inner frame
door corner reinforcement
