This part caused me a bit of problem mainly because there are so many sheets of aluminium that need to connect to give strenght. So, even though all bits are well prepared there is a lot of bending and squeesing before it's done. This is particularily notable around the main gear compartment and the connections of the seat longeron and the side wall. The task seems impossible to start with but with the stepwise use of clecoes (and some brutal force) all pieces will fit and give very strong connection points. Please remember to add the AN-bolts in the holes of SF305/306 for the seat belts before rivetting them to the central tunnel !!The manual doesn't warn you.
My garage has become too low for the project and I need to cut the table by some 20 cm before I can take on the new tasks!!
