Brief Description: Rotisserie for Fuselage Painting
- Rotisserie for the fuselage was manufactured from steel angle section, hollow square sections and tubing.
- The front support was attached to the engine mounts, while the rear support was replacing the tail wheel attchment using these mounting holes and bracket.
- The rear mount was fixed to a an engine stripping carrier on coasters. this allowed the easy movement inside the workshop. The front bracket was supported by a hydraulic engine hoist to allow vertical adjustments of the fuselage.
- This arrangement allowed a 360degree rotation of the fuselage during all the painting
