HANSRUDOLF'S WEB SITE
Date:  9-12-2017
Number of Hours:  8.00
Brief Description:  Cockpit Roof - Skylight 1/2
Polycarbon sheets were used to construct the skylight.
- Initial work included the welding of flat (1") stainless steel strips to the existing ribstructure (wingroots) and steel lugs to the partial ribs in the centre (behind windshield)
- Painting of all new weld joints
- Fitting and rivetting aluminium flat strips to the steel lugs and aluminium framing
- Cutting and fitting of polycarbon sheets and rivetting sheets to roof support
- Applying silicon beads to sheet joints and rivetting aluminium cover strips over joints to complete the skylight
Stainless flat steel strips welded to wingroot rib
Stainless flat steel stribs welded/rivetted to partial centre ribs (front)
Aluminium flat strips rivetted to aluminium roof framing
