HANSRUDOLF'S WEB SITE
BearHawk
Instrument Panel
9-11-2017
Dashboard for Instrument Panel
Dashboard Construction
The dashboard was made of poly carbon sheet left over from cabin windows
Strip was heat preformed to the instrument curvature and then padded and covered with material
Poly Carbon sheet cut to shape
Dashboard temporaily fitted to check fit
Dashboard in process of covering
BearHawk Home
2029
Airframe Practical C
Aux Fuel Pump
Brake System
Cabin Fitout
Cockpit Roof
Colour Top Coats
Control Cables
Control Surfaces (Ai
Electrical Wiring
Engine Control Cable
Engine Stand
Fairings and Gap Sea
Flap Control System
Fuselage Air Intake
Fuselage Cowl
Fuselage Fitout
Fuselage Floorboards
Fuselage Nosebowl
Fuselage Panels
Fuselage Rotisserie
Gear Legs
Gear Strut
Heating/Cooling Sys
Instrument Panel
IO 360 Sensor Wiring
IO-360 A1A Engine
Navigation Lights
Pneumatic Lines
Poly-Fibre Covering
Port Wing
Seat Belts
Seats
Starboard Wing
Window Framing
Windshield
Wing Painting
Wings - Fitout/Paint
