HANSRUDOLF'S WEB SITE
BearHawk
Pneumatic Lines
3-3-2017
Pneumatic System - 1/2
Pneumatic System - Static Port Lines
Static Ports wwere installed behind the cabin on either side of the fuselage
Static port line includes a drainage port at the low point at the pilot side of the aircraft which can be accessed to allow alternate air source should the line get blocked
Staic port mounted on stringers behind fuselage
Pneumatic Lines connected to instruments
Static System drainage point on pilot's side
BearHawk Home
2029
Airframe Practical C
Aux Fuel Pump
Brake System
Cabin Fitout
Cockpit Roof
Colour Top Coats
Control Cables
Control Surfaces (Ai
Electrical Wiring
Engine Control Cable
Engine Stand
Fairings and Gap Sea
Flap Control System
Fuselage Air Intake
Fuselage Cowl
Fuselage Fitout
Fuselage Floorboards
Fuselage Nosebowl
Fuselage Panels
Fuselage Rotisserie
Gear Legs
Gear Strut
Heating/Cooling Sys
Instrument Panel
IO 360 Sensor Wiring
IO-360 A1A Engine
Navigation Lights
Pneumatic Lines
Poly-Fibre Covering
Port Wing
Seat Belts
Seats
Starboard Wing
Window Framing
Windshield
Wing Painting
Wings - Fitout/Paint
