HANSRUDOLF'S WEB SITE
Date:  10-4-2018
Number of Hours:  10.00
Brief Description:  USB Charger for Nav iPad
USB Charger for iPad
Double charging points were required to run an iPad based OzRunways (RWY) programme, a CASA approved Electronic Flight Bag
The required charger needed to have a 3Amp capacity and needed to deliver a no ripple output, as not to interfere with any of the electronic onboard equipment.
The charger is based on a TI LM 2576 - 3A Step-Down Voltage Regulator (refer to Image 3). I have added an additional low output ripple filter (L2/100uF Cap) to achieve a 10 or more times reduction of output ripple.
The unit is housed in a standard 50x50x40mm diecast box and fitted with USB cables, cut to suit. The unit will be mounted under the subpanel for easy access.
Completed assembly
Completed assembly
Bracket to mount the USB point under the subpanel
Circuit and corresponding board layout
