HANSRUDOLF'S WEB SITE
Date:  3-3-2016
Number of Hours:  10.00
Manual Reference:  4/5
Brief Description:  Engine Baffle Installation
Modified Vans Air Engine Baffle Kit Installation
- Installed an extension piece to the side baffle to adjust for the angled cylinder head of the IO-360
- Radiused both the side baffle extension and the RHS of the front baffle to achieve a smooth transition and drilled and rivetted the pieces in place
- Prepared a radiused joiner piece between the intake and the vertical wall of the centre baffle to achieve a smooth transition. Drilled and rivetted the pieces in place
Note: The front right quarters of the baffle (RHS centre, front and side baffle) are all rivetted together and form a single baffle piece which can be removed during engine maintenance without drilling out any rivets as a single piece
Initial installation of front RHS baffle
Radiused front RHS between centr and side baffle
Radiused insert between front and vertical wall of centre baffle
