Brief Description: Installation of 3/8" Fuel Lines (Fwd)
Installation of 3/8" Alu Fuel lines in Fuselage
- Prepared bends in fuel line to suit fuselage frame work - Prepared and welded revised Fuel Line Mounting Bracket, as per "Engineering Notice, January 2011" to allow a better alignment of the aft fuelline connection to the Tee-Fitting (refer Image 3) - Installed AN-6 Tee in bracket - Installed fuelline in frame - Fitted AN-6 fittings to fuel and flared ends - Completed forward fuelline from Wingroot to Tee Fitting
Wing Root alignment of fuel line
Fuelline alignment at the the instrument panel location
