HANSRUDOLF'S WEB SITE
BearHawk
Port Wing
1-31-2015
Run conduit for Nav/Strobe lights, pump and pitot
Electrical Conduit Installation:
- Prepared doublers for rib penetrations and installed doublers
- Prepared support brackets for conduit at rib lighting holes
- Run conduit from wing tip to root rib for Nav/Strobe light and trnsfer pump circuit
- Install second conduit for heated pitot tube and AoA pre-stall warner
Conduit run to wing tip/pitot location
Twin conduit crossing over flap actuator
Twin conduit at root rib
BearHawk Home
2029
Airframe Practical C
Aux Fuel Pump
Brake System
Cabin Fitout
Cockpit Roof
Colour Top Coats
Control Cables
Control Surfaces (Ai
Electrical Wiring
Engine Control Cable
Engine Stand
Fairings and Gap Sea
Flap Control System
Fuselage Air Intake
Fuselage Cowl
Fuselage Fitout
Fuselage Floorboards
Fuselage Nosebowl
Fuselage Panels
Fuselage Rotisserie
Gear Legs
Gear Strut
Heating/Cooling Sys
Instrument Panel
IO 360 Sensor Wiring
IO-360 A1A Engine
Navigation Lights
Pneumatic Lines
Poly-Fibre Covering
Port Wing
Seat Belts
Seats
Starboard Wing
Window Framing
Windshield
Wing Painting
Wings - Fitout/Paint
