HANSRUDOLF'S WEB SITE
BearHawk
Starboard Wing
1-9-2015
Tank Cover Plates
Tank Cover Plates for Main and Aux Tanks:
- Prepared cover plates and and flanged edges
- Aligned coverplates and located quick drain locations
- Cut holes for quick drains and installed rubber grommets
- Installed cover plates
Cover plate with flanged edges (typical)
Quick drain hole with rubber grommet
BearHawk Home
2029
Airframe Practical C
Aux Fuel Pump
Brake System
Cabin Fitout
Cockpit Roof
Colour Top Coats
Control Cables
Control Surfaces (Ai
Electrical Wiring
Engine Control Cable
Engine Stand
Fairings and Gap Sea
Flap Control System
Fuselage Air Intake
Fuselage Cowl
Fuselage Fitout
Fuselage Floorboards
Fuselage Nosebowl
Fuselage Panels
Fuselage Rotisserie
Gear Legs
Gear Strut
Heating/Cooling Sys
Instrument Panel
IO 360 Sensor Wiring
IO-360 A1A Engine
Navigation Lights
Pneumatic Lines
Poly-Fibre Covering
Port Wing
Seat Belts
Seats
Starboard Wing
Window Framing
Windshield
Wing Painting
Wings - Fitout/Paint
