HANSRUDOLF'S WEB SITE
BearHawk
Starboard Wing
11-13-2014
Inner and outer control surface hinges
Permanent Installation of Aileron and Flap Hinges:
- Reinstalled aileron and flap using wing profile template
- Final alignment of hing location in support tubes
- Secured hinges in support tubes using structural rivets (CherryMax Rivets, 2 /3 No. per bearing support tube)
- Checked final alignment and smooth operation without any binding - Checked out O.K.
Final alignment check
Secured aileron main hinge bearing with CherryMax
Secured flap main hinge bearing with CherryMax rivets
BearHawk Home
2029
Airframe Practical C
Aux Fuel Pump
Brake System
Cabin Fitout
Cockpit Roof
Colour Top Coats
Control Cables
Control Surfaces (Ai
Electrical Wiring
Engine Control Cable
Engine Stand
Fairings and Gap Sea
Flap Control System
Fuselage Air Intake
Fuselage Cowl
Fuselage Fitout
Fuselage Floorboards
Fuselage Nosebowl
Fuselage Panels
Fuselage Rotisserie
Gear Legs
Gear Strut
Heating/Cooling Sys
Instrument Panel
IO 360 Sensor Wiring
IO-360 A1A Engine
Navigation Lights
Pneumatic Lines
Poly-Fibre Covering
Port Wing
Seat Belts
Seats
Starboard Wing
Window Framing
Windshield
Wing Painting
Wings - Fitout/Paint
