HANSRUDOLF'S WEB SITE
BearHawk
Windshield Installation 1/2
Windshield was trial fitted and using masking tape to identify tight areas requiring grinding
Cut-off wheel was used to remove tight areas and also allow the trimming of the windshield to match the cowling angles
Repeated trial fitting and trimming achieved close fit with hardly any gaps.
Masking tape was used to mark tight areas
Trimming of windshield with cut-off grinder to adjust contour and to match the angle
Completed contouring showing close fit
BearHawk Home
2029
Airframe Practical C
Aux Fuel Pump
Brake System
Cabin Fitout
Cockpit Roof
Colour Top Coats
Control Cables
Control Surfaces (Ai
Electrical Wiring
Engine Control Cable
Engine Stand
Fairings and Gap Sea
Flap Control System
Fuselage Air Intake
Fuselage Cowl
Fuselage Fitout
Fuselage Floorboards
Fuselage Nosebowl
Fuselage Panels
Fuselage Rotisserie
Gear Legs
Gear Strut
Heating/Cooling Sys
Instrument Panel
IO 360 Sensor Wiring
IO-360 A1A Engine
Navigation Lights
Pneumatic Lines
Poly-Fibre Covering
Port Wing
Seat Belts
Seats
Starboard Wing
Window Framing
Windshield
Wing Painting
Wings - Fitout/Paint
