All conncetion for the vaccuum lines were made using Nylo-Seal Fittings
Static ports were installed in the rear fuselage just aft of the cabin.
A alternate static air supply is install in the low point of the static port line, below the door next to the pilots seat. This line serves both as a drainage point for any water and also as a secondary static port air source.
