HANSRUDOLF'S WEB SITE
BearHawk
Avionics - Wiring 2/2
Avionics Wiring 2/2
Following initial preparation of the wiring looms on the work bench, the remainder of the wiring was undertaken insitu, i.e. in the aircraft.
Each wire was labelled with regards to type of connection, connector number and the specific pin allocation at both ends of the wire.
Picture 1: Avionics Bay, Engine Management Instrument and GDU 370 wiring.
Picture 2: Radio Stack wiring
Picture 3: Power Supply Panel wiring
Wiring behind Instrument Panel - Note labelling
Radio Stack
Power Supply Panel
BearHawk Home
2029
Airframe Practical C
Aux Fuel Pump
Brake System
Cabin Fitout
Cockpit Roof
Colour Top Coats
Control Cables
Control Surfaces (Ai
Electrical Wiring
Engine Control Cable
Engine Stand
Fairings and Gap Sea
Flap Control System
Fuselage Air Intake
Fuselage Cowl
Fuselage Fitout
Fuselage Floorboards
Fuselage Nosebowl
Fuselage Panels
Fuselage Rotisserie
Gear Legs
Gear Strut
Heating/Cooling Sys
Instrument Panel
IO 360 Sensor Wiring
IO-360 A1A Engine
Navigation Lights
Pneumatic Lines
Poly-Fibre Covering
Port Wing
Seat Belts
Seats
Starboard Wing
Window Framing
Windshield
Wing Painting
Wings - Fitout/Paint
