HANSRUDOLF'S WEB SITE
Date:  5-15-2016
Number of Hours:  25.00
Brief Description:  Oil Cooler Manifold and Support Bracket
Oil Cooler Manifold and Support Brackets:
- Given the anecdotal evidence of fatigue cracking of the rear baffle on many installation, I decided to remotely mount the oil cooler on a support frame fixed to the engine mount and connect the oil cooler with a SCAT tube to the cold air supply from the baffle plenum.
- templates for the aluminium manifold was then created from a shaped polystyrene foam core, which allowed then to create the expanded view of all cutting planes. Assembly was a fully rivetted box
Shaped foam core and cardboard template
Intake manifold with support frame
Oil Cooler with support frame
