Brief Description: Brakeline in Undercarriage legs
1/4" Alu Brake line Installation in LHS Undercarriage Leg
- Bent and cut to length 1/4" aluminium pipes to fit between top of leg and brake Puck brake fitting - Fitted AN-4 Fittings to lines and flared ends - Fitted top of brakeline to Right Angle AN-4 bulkhead fitting - Fitted bottom of line to Grove Double Puck brake. Decided not to install a flexible connection, given the very minimal movement of the line in this location - Fixed brakline to the lugs provided on the legs with rubber cushioned clamps
Note: RHS brakeline installation was mirrored.
Upper connection to bulkhead fitting including pipe clamp to leg
Lower brakeline connection to Grove brakes including pipe clamp to leg
