HANSRUDOLF'S WEB SITE
BearHawk
Install Trim Wheel
Install Trim Wheel:
- Installed trim wheel on airframe
- Prepare chain drive by inserting bushings and rivet axle at each end for connection to cable run
- Prepare 3/32 inch cables for trim control (swaged eye connection to front end of cables)
- Attached swaged turnbuckle to one end and eye connection to other cable for tail end of cable run
- Installed cable fairleads in airframe and run trim cable.
Installed trim wheel, chain and swaged cable connection.
Fairlead for trim cable at rear of fuselage
Turnbuckle and shackle connection to trim horn
BearHawk Home
2029
Airframe Practical C
Aux Fuel Pump
Brake System
Cabin Fitout
Cockpit Roof
Colour Top Coats
Control Cables
Control Surfaces (Ai
Electrical Wiring
Engine Control Cable
Engine Stand
Fairings and Gap Sea
Flap Control System
Fuselage Air Intake
Fuselage Cowl
Fuselage Fitout
Fuselage Floorboards
Fuselage Nosebowl
Fuselage Panels
Fuselage Rotisserie
Gear Legs
Gear Strut
Heating/Cooling Sys
Instrument Panel
IO 360 Sensor Wiring
IO-360 A1A Engine
Navigation Lights
Pneumatic Lines
Poly-Fibre Covering
Port Wing
Seat Belts
Seats
Starboard Wing
Window Framing
Windshield
Wing Painting
Wings - Fitout/Paint
