HANSRUDOLF'S WEB SITE
BearHawk
Installation of Control Stick Assembly
Installation of Control Stick Assembly:
- Install aileron and elevator/flap pulleys in fuselage
- Temporarily install flap actuator assembly and connect string from flap handle to flap pulley
- Temporarily install stick control assembly and align aileron control with aileron pulleys
- Align stick assembly and elevator control with elevator pulleys and check clearance with flap control cable
- Drill AN3 holes for stick assembly to fuselage installation
- Install floor panels forward of front seats, drill matching AN3 holes and bolt stick assembly through floor board to fuselage
Temporarily install stick assembly and check alignment with elevator and aileron pulleys
Installation of floor panel in rudder well
Check alignment with aileron pulley and bolt assembly through floor board to airframe
BearHawk Home
2029
Airframe Practical C
Aux Fuel Pump
Brake System
Cabin Fitout
Cockpit Roof
Colour Top Coats
Control Cables
Control Surfaces (Ai
Electrical Wiring
Engine Control Cable
Engine Stand
Fairings and Gap Sea
Flap Control System
Fuselage Air Intake
Fuselage Cowl
Fuselage Fitout
Fuselage Floorboards
Fuselage Nosebowl
Fuselage Panels
Fuselage Rotisserie
Gear Legs
Gear Strut
Heating/Cooling Sys
Instrument Panel
IO 360 Sensor Wiring
IO-360 A1A Engine
Navigation Lights
Pneumatic Lines
Poly-Fibre Covering
Port Wing
Seat Belts
Seats
Starboard Wing
Window Framing
Windshield
Wing Painting
Wings - Fitout/Paint
