HANSRUDOLF'S WEB SITE
BearHawk
Assembly of shock struts
Assembly of Shock Struts:
- Turned down and polished strut rod plunger at top over length of strut operation to achieve smooth operation with bronze top cap
- checked operation of top cap to esure no tight spots over range of operation
- Installed O-rings in piston and top cap and installed plunger in strut casing
Polished strut rod end
Compression spring installed
Top cap placed on plunger
BearHawk Home
2029
Airframe Practical C
Aux Fuel Pump
Brake System
Cabin Fitout
Cockpit Roof
Colour Top Coats
Control Cables
Control Surfaces (Ai
Electrical Wiring
Engine Control Cable
Engine Stand
Fairings and Gap Sea
Flap Control System
Fuselage Air Intake
Fuselage Cowl
Fuselage Fitout
Fuselage Floorboards
Fuselage Nosebowl
Fuselage Panels
Fuselage Rotisserie
Gear Legs
Gear Strut
Heating/Cooling Sys
Instrument Panel
IO 360 Sensor Wiring
IO-360 A1A Engine
Navigation Lights
Pneumatic Lines
Poly-Fibre Covering
Port Wing
Seat Belts
Seats
Starboard Wing
Window Framing
Windshield
Wing Painting
Wings - Fitout/Paint
