HANSRUDOLF'S WEB SITE
BearHawk
Flap torque tube alignment and cable installation
Flap Torque Tube Alignment and Cable Installation:
- Marked location of flap settings on wing root
- Checked alignment with fuselage mounted pulley using template
- Drilled and bolted actator lever to torque tube
Flap position marks on wing root using template mounted on wing attachment point
Template for flap alignment check
Bolted actuator levers to torque tube
BearHawk Home
2029
Airframe Practical C
Aux Fuel Pump
Brake System
Cabin Fitout
Cockpit Roof
Colour Top Coats
Control Cables
Control Surfaces (Ai
Electrical Wiring
Engine Control Cable
Engine Stand
Fairings and Gap Sea
Flap Control System
Fuselage Air Intake
Fuselage Cowl
Fuselage Fitout
Fuselage Floorboards
Fuselage Nosebowl
Fuselage Panels
Fuselage Rotisserie
Gear Legs
Gear Strut
Heating/Cooling Sys
Instrument Panel
IO 360 Sensor Wiring
IO-360 A1A Engine
Navigation Lights
Pneumatic Lines
Poly-Fibre Covering
Port Wing
Seat Belts
Seats
Starboard Wing
Window Framing
Windshield
Wing Painting
Wings - Fitout/Paint
