HANSRUDOLF'S WEB SITE
BearHawk
Install Plumbing of Aux and Main Tank
Fuel Line System for Fuel Transfer and Main Supply Line:
- Install mfuel transfer pump support plate (rivet to back spar (typical)
- Locate fuel line rib penetrations, install rubber grommets (typical)
- Install overflow and fuel line to pump
-Install transfer fuel line from pump to main tank (connect line to upper sighting gauge line
-Install all lines strainers to main outlet and complete plumbing of main tank
Port Wing Aux Tank plumbing
Port Wing Fuel Transfer pump
Port Wing Main Tank plumbing
BearHawk Home
2029
Airframe Practical C
Aux Fuel Pump
Brake System
Cabin Fitout
Cockpit Roof
Colour Top Coats
Control Cables
Control Surfaces (Ai
Electrical Wiring
Engine Control Cable
Engine Stand
Fairings and Gap Sea
Flap Control System
Fuselage Air Intake
Fuselage Cowl
Fuselage Fitout
Fuselage Floorboards
Fuselage Nosebowl
Fuselage Panels
Fuselage Rotisserie
Gear Legs
Gear Strut
Heating/Cooling Sys
Instrument Panel
IO 360 Sensor Wiring
IO-360 A1A Engine
Navigation Lights
Pneumatic Lines
Poly-Fibre Covering
Port Wing
Seat Belts
Seats
Starboard Wing
Window Framing
Windshield
Wing Painting
Wings - Fitout/Paint
