HANSRUDOLF'S WEB SITE
BearHawk
Install aileron and flap on wing
Installation of Aileron and Flap:
- Installed control surface hinge bearings in support tubes
- Aligned aileron and flap for designed gap and location using wing profile template and adjusted location of hinge bearings in support tubes
- Needed to adjust alignment of rear aileron actuator arm support bracket to center aileron pushrod in opening through rear spar
- Marked location of hinge brackets and installed hinge brackets on aileron and flap, torqued bolts.
- Installed flap return springs on actuator arm
Flap support hinge
Flap actuator hing and return springs
Adjusted Aileron hinge/pushrod alignment
BearHawk Home
2029
Airframe Practical C
Aux Fuel Pump
Brake System
Cabin Fitout
Cockpit Roof
Colour Top Coats
Control Cables
Control Surfaces (Ai
Electrical Wiring
Engine Control Cable
Engine Stand
Fairings and Gap Sea
Flap Control System
Fuselage Air Intake
Fuselage Cowl
Fuselage Fitout
Fuselage Floorboards
Fuselage Nosebowl
Fuselage Panels
Fuselage Rotisserie
Gear Legs
Gear Strut
Heating/Cooling Sys
Instrument Panel
IO 360 Sensor Wiring
IO-360 A1A Engine
Navigation Lights
Pneumatic Lines
Poly-Fibre Covering
Port Wing
Seat Belts
Seats
Starboard Wing
Window Framing
Windshield
Wing Painting
Wings - Fitout/Paint
