Ross's RV-7 Build Log
Date:  10-31-2008
Number of Hours:  24.00
Brief Description:  Final few touches
A moisture extractor and pressure regulator were fitted to the air supply lines. We mounted the air compressor on the wall outside the hangar in order to keep noise levels down.
After much deliberation the workshop benches were put in their place and levelled. Notice boards (reclaim yard find) were hung on the walls, which will come in handy. Note the architects table in the bottom pic (another reclaim yard find), which will also come in handy for holding the construction drawings.
The next plan is to build a spray booth under the mezz. This will consist of a wooden frame covered down with plastic sheeting. An extractor fan will also be installed in the booth to remove paint fumes.
Air line final touches
Coming together
Coming together
