Finished filing shape fcor bell crank mount. made a 16.5 MM spacer positioned & drilled & clecoed. drilled & rivited tip to spar also cut out "L" angle for wing tip drilled & clecoed into position. deburred lightening holes in all 9 rear ribs. started cutting "L" angle supports for walk way for ribs 1 thru 3.
