On August 5, 2013, the propeller arrived from Hartzell. This is the HC-C3Y1R-1N//N7605C a composite prop with a stainless core three bladed prop. I ordered it through Vans and it shipped directly from Hartzell.
The 15″ spinner will be coming from a local shop in Pearland, TX at Pearland Regional Airport. This is a polished spinner. The reason it is 15″, actually something more like 14.7/8″, is because of the Show Planes RV10 cowl that I will be using. I also order a control arm from Hartzell that will be sourced from the Pearland shop. The control arm is P/N: C-4582-P and the spinner part number is D-7709P.
