Aug 14th, 2013 – 2 hours. I was able to complete the mounting bracket plate the oxygen tank will be mounted onto and got it riveted in. Working in those small areas just aren’t fun when your “special” angle drill keeps slipping gears and wont turn the drill bit. Frustrating!! Another frustrating event that occurred was I routed the 1/8″ copper tube for the refill line for the tank and I didn’t realize that the end connector had two small wedge pieces that are supposed to be installed. I installed the copper tubing with only the large wedge piece around the copper tubing and then realized after I had “squished” the fitting that this wasn’t they way it was supposed to work! Im ordering more parts from Mountain High now so I will order some of these fittings also. Something told me it wasn’t right and I certainly need this line to hold since it will have 2000 to 3000 PSI on it. I have also included a picture of the refill station located under the baggage floor.
