Aug 11-12th, 2013 – 4 hours I started working with the Mountain High EDS-4ip Aviation Oxygen System. First I unpacked the box to figure out what I was working with. I decided on mounting the the Deluxe fill station with gauge and the (current) 3/8-24 (MS22066) fitting under the baggage area. It is located under the access door in the baggage area. I do not have picture of this install at this time but will in the future since it is not plumbed yet. The unit hides nicely out of the way and is very easy to access when it will need to be recharged.
i am mounting the Oxygen tank on the starboard side of the aircraft since I cannot fit it on the port side located adjacent to the rear standard battery location. On the port side is also the strobe light system not allowing enough room for access. I will be mounting the oxygen bottle horizontal and not vertical as I original wished since the air conditioning tray interferes with the height of the oxygen bottle. I have not completely installed the mounts yet but have drilled the mounting holes only at this point.
