Sept 14th, 2013. 1 hour I finally ordered the replacement 1/8″ compression Ferrule so i could finish installing the 1/8″ refill line from the refill station to the tank. All lines flushed and torqued per manufactures guidance – Swage Lock. (3/4 turn after finger tight and tubing not moving)
00HDW-02120BB – 1/8″ Comp Ferrule Back Brass 00HDW-02120FB – 1/8″ Comp Ferrule Front Brass
