Brief Description: Flightline AC, Evaporator to Overhead Tarnistion
Feb 23rd, 2013, 8 hours. Started the morning by using West Epoxy Systems to adhere almost all the overhead tranistions toagther. I did not adhere the ramp section to the close out panel that attaches to the evaporator yet. I still need to attach the ramp union piece to the overhead section that will remain with the overhead mounted to the cabin top. This will require everything to be in place and then some epoxy will be used to temporarily hold the angle required. Then I can final epoxy it in place to the overhead.
