Brief Description: Aft 12Volt Battery Power and associated Terminal/F
This weekend (Jan 27, 2013) I spent 9 hours working on various aspects of installing the remaining aft section of the 4 AWG wire coming from the Tunnel AUX Battery. I started by installing a Blue Sea ST Blade Fuse Blocks (Overton’s p/n: 71230) that includes a negative bus and positive bus. Max amperage is 100 Amps the block can handle. Max amperage is 30 Amps per circuit.
Before I could mount the block where I finally decided to mount it, I had to remove my previously modified battery box location that was modified to hold two batteries since I did not need the extra weight back there. I drilled out the rivets holding the double battery mount to remove it. Once I did this, I had clear access to where I wanted to mount the fuse block.
I mounted the fuse block and then terminated the 4 AWG switched wire coming from the Tunnel AUX bus and terminated a 4 AWG ground wire to the block. I then moved onto creating a support bracket to hold the wires and conduit exiting the aft baggage deck.
