GAYLON'S WEB SITE
Date:  9-27-2013
Manual Reference:  none
Brief Description:  Install of Roll and Pitch Servo – Garmin GSA 28
Sept 26-27, 2013. 2 Hours
I installed the Garmin GSA 28 Roll and Pitch servos. Printed out the RV10 install instructions and sat down by the wing and installed the GSA-28 Roll Servo with minimal issues in the wing. The GSA-28 install in the tail cone area of the RV10 was a little more of an issue since I have the Airflow Performance AC installed that sort of interferes with gaining access to that area. All nuts/bolts torqued to manufactures specs and marked with torque seal.
I did go back on Sept 28th and install the proper washer and nut, torqued and torque sealed the horizontal pushrod connector bolt seen in the photos.
