Brief Description: Section 37, Fuel System - Andair Fuel Valve
December 28, Sectioned the tunnel cover into 3 different section. First section is forward of the brake pedals, second section was from aft brake pedal system to where the fuel valve is mounted. The third section is aft the fuel valve to the end of the original tunnel cover. This allows easier access to all the tunnel sections and allowed the fuel selector valve to be mounted much higher in the tunnel to allow a better fit with the carbon fiber center armrest. Spent 4 hours
