I decided to recess the door hinge locations to lower the top of the hinges to be flush with the surrounding cabin top plus this was a chance to level the surface where the hinges attach. I then aligned the hinges per the plans and drilled the associated holes. I also dimpled the #30 holes in the tail cone skin plus drilled all three rivet doubler pieces for backing the inside of the cabin attach point. Worked 4 hours total, between Nov 14-15.
