Continued with running tunnel brake lines and measured the brake lines for the Control Approach Pedals. I am ordering the brake lines from Bonaco. Spent 7 hours doing this on Oct 6th.
QTY 2: -3 Hose assy w/clear at 37” OVL -3 straight to -3 straight QTY 3: -3 Hose assy w/clear at 12” OVL -3 straight to -3 straight QTY 1: -3 Hose assy w/clear at 12” OVL -3 straight to -3 90 degree QTY 2: -3 Hose assy w/clear at 31.5” OVL -3 (with -4 Nuts each end) straight to -3 straight. This is for the gear legs from belly to caliper. QTY 1: 826-3D, for replacing stock plastic “T” QTY 8: 822-3D, 1/8 NPT to -3 male 90
